[GRASS-dev] v.in.lidar return filter
Anna Petrášová
kratochanna at gmail.com
Tue Sep 23 08:40:00 PDT 2014
On Tue, Sep 23, 2014 at 8:19 AM, Newcomb, Doug <doug_newcomb at fws.gov> wrote:
> It looks like the same patch needs to be applied to r.in.lidar main.c
> before line 791. So modifying to the following for both v.in.lidar and
> r.in.lidar main.c should fix both?
> if (n_returns == 1) {
> switch (return_filter) {
> case LAS_FIRST:
> if (return_no == 1)
> skipme = 0;
> break;
> if (n_returns > 1) {
> case LAS_FIRST:
> if (return_no == 1)
> skipme = 0;
> break;
> case LAS_LAST:
> if (return_no == n_returns)
> skipme = 0;
> break;
> case LAS_MID:
> if (return_no > 1 && return_no < n_returns)
> skipme = 0;
> break;
Thanks, I rewrote it but it should be hopefully the same logic:
case LAS_FIRST:
if (return_no == 1)
skipme = 0;
break;
case LAS_MID:
skipme = 0;
break;
case LAS_LAST:
if (n_returns > 1 && return_no == n_returns)
skipme = 0;
break;
Committed in r62055 and backported.
Anna
> Doug
> On Tue, Sep 23, 2014 at 8:05 AM, Newcomb, Doug <doug_newcomb at fws.gov>
> wrote:
>> I don't think it was intentional to drop first and only returns, but if
>> it is the first and only return the filter for First and Last Return would
>> both match.
>> Putting another if statement in front along the lines of if(n_returns ==
>> 1) set case LAS_FIRST should fix it.
>> Doug
>> On Mon, Sep 22, 2014 at 6:54 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> Hi,
>>> I want to import first return points with v.in.lidar, but I get only
>>> points where the pulse had more then one return. So it gives me trees but
>>> not ground or buildings. I looked in the code and there is an 'if' which
>>> skips points with only 1 return:
>>> http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.lidar/main.c#L672
>>> So the behavior looks intentional but what's the reason?
>>> Thanks,
>>> Anna
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Doug Newcomb
>> USFWS
>> Raleigh, NC
>> 919-856-4520 ext. 14 doug_newcomb at fws.gov
>> The opinions I express are my own and are not representative of the
>> official policy of the U.S.Fish and Wildlife Service or Dept. of the
>> Interior. Life is too short for undocumented, proprietary data formats.
> Doug Newcomb
> USFWS
> Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140923/17d1b3e0/attachment.html>
