[GRASS-dev] v.in.lidar return filter
Newcomb, Doug
doug_newcomb at fws.gov
Tue Sep 23 09:51:12 PDT 2014
Much better :-) !
On Tue, Sep 23, 2014 at 11:40 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, Sep 23, 2014 at 8:19 AM, Newcomb, Doug <doug_newcomb at fws.gov>
> wrote:
>> It looks like the same patch needs to be applied to r.in.lidar main.c
>> before line 791. So modifying to the following for both v.in.lidar and
>> r.in.lidar main.c should fix both?
>> if (n_returns == 1) {
>> switch (return_filter) {
>> case LAS_FIRST:
>> if (return_no == 1)
>> skipme = 0;
>> break;
>> if (n_returns > 1) {
>> case LAS_FIRST:
>> if (return_no == 1)
>> skipme = 0;
>> break;
>> case LAS_LAST:
>> if (return_no == n_returns)
>> skipme = 0;
>> break;
>> case LAS_MID:
>> if (return_no > 1 && return_no < n_returns)
>> skipme = 0;
>> break;
> Thanks, I rewrote it but it should be hopefully the same logic:
> case LAS_FIRST:
> if (return_no == 1)
> skipme = 0;
> break;
> case LAS_MID:
> skipme = 0;
> break;
> case LAS_LAST:
> if (n_returns > 1 && return_no == n_returns)
> skipme = 0;
> break;
> Committed in r62055 and backported.
> Anna
>> Doug
>> On Tue, Sep 23, 2014 at 8:05 AM, Newcomb, Doug <doug_newcomb at fws.gov>
>> wrote:
>>> I don't think it was intentional to drop first and only returns, but if
>>> it is the first and only return the filter for First and Last Return would
>>> both match.
>>> Putting another if statement in front along the lines of if(n_returns
>>> == 1) set case LAS_FIRST should fix it.
>>> Doug
>>> On Mon, Sep 22, 2014 at 6:54 PM, Anna Petrášová <kratochanna at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I want to import first return points with v.in.lidar, but I get only
>>>> points where the pulse had more then one return. So it gives me trees but
>>>> not ground or buildings. I looked in the code and there is an 'if' which
>>>> skips points with only 1 return:
>>>> http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.lidar/main.c#L672
>>>> So the behavior looks intentional but what's the reason?
>>>> Thanks,
>>>> Anna
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>> Doug Newcomb
>>> USFWS
>>> Raleigh, NC
>>> 919-856-4520 ext. 14 doug_newcomb at fws.gov
>>> The opinions I express are my own and are not representative of the
>>> official policy of the U.S.Fish and Wildlife Service or Dept. of the
>>> Interior. Life is too short for undocumented, proprietary data formats.
>> Doug Newcomb
>> USFWS
>> Raleigh, NC
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140923/4005728d/attachment-0001.html>
