[GRASS-dev] G7 blockers call
Anna Petrášová kratochanna at gmail.com
Thu Sep 25 06:56:59 PDT 2014
On Thu, Sep 25, 2014 at 9:30 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Hi Anna,
> Anna Petrášová wrote
> > On Fri, Sep 5, 2014 at 4:17 PM, Helmut Kudrnovsky <
> > hellik@
> > > wrote:
> >> >>But doing the steps from the
> >> >> installer manually works (the third suggestion). This was the case on
> >> >> two (or more) computers already.
> >> >I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
> >> >Installing with admin priviliges and checking the box for the MS
> runtime
> >> >environments didn't help but copying the DLLs manually to extrabin did
> >> >the trick (as suggested in [1]).
> >> which windows version (7, 8)? any antivirus software?
> > I saw the problem with both versions. I can't check the antivirus now but
> > that might be causing it.
> >> the winGRASS standalone installer should copy the DLLs to extrabin, see
> > the dlls are not there although the installation seems to finish
> correctly
> > Anna
> by r61832, r61843, r61911, r61951, r62082 I've tried to attempt to fix
> installing and copying MS runtime files.
> at least here on my windows box, where installing and copying MS runtimes
> files previously failed, the windows standalone installer does now the job.
> any chance to test standalone winGRASS7.1
> (http://wingrass.fsv.cvut.cz/grass71/) above r62082?
Great, I will try tomorrow. I need to ask someone to try it, on the
computers I have access to, it was working before. Have you identified the
problem or are you still guessing?
Thanks!
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164138.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140925/e7483144/attachment.html>
