[GRASS-dev] G7 blockers call
Helmut Kudrnovsky hellik at web.de
Thu Sep 25 06:30:12 PDT 2014
Hi Anna,
Anna Petrášová wrote
> On Fri, Sep 5, 2014 at 4:17 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> >>But doing the steps from the
>> >> installer manually works (the third suggestion). This was the case on
>> >> two (or more) computers already.
>> >I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
>> >Installing with admin priviliges and checking the box for the MS runtime
>> >environments didn't help but copying the DLLs manually to extrabin did
>> >the trick (as suggested in [1]).
>> which windows version (7, 8)? any antivirus software?
> I saw the problem with both versions. I can't check the antivirus now but
> that might be causing it.
>> the winGRASS standalone installer should copy the DLLs to extrabin, see
> the dlls are not there although the installation seems to finish correctly
> Anna
by r61832, r61843, r61911, r61951, r62082 I've tried to attempt to fix
installing and copying MS runtime files.
at least here on my windows box, where installing and copying MS runtimes
files previously failed, the windows standalone installer does now the job.
any chance to test standalone winGRASS7.1
(http://wingrass.fsv.cvut.cz/grass71/) above r62082?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164138.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
