[GRASS-dev] G7 blockers call
Johannes Brauner
johannes.brauner at tu-dresden.de
Fri Sep 26 00:48:19 PDT 2014
Hi Helmut,
On 25.09.2014 15:35, Helmut Kudrnovsky wrote:
> Johannes Brauner wrote
>> Hi,
>> On 05.09.2014 23:57, Anna Petrášová wrote:
>>> On Fri, Sep 5, 2014 at 4:17 PM, Helmut Kudrnovsky <
>> hellik@
>> > <mailto:
>> hellik@
>> >> wrote:
>>> >>But doing the steps from the
>>> >> installer manually works (the third suggestion). This was the case
>>> on
>>> >> two (or more) computers already.
>>> >I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
>>> >Installing with admin priviliges and checking the box for the MS
>>> runtime
>>> >environments didn't help but copying the DLLs manually to extrabin
>>> did
>>> >the trick (as suggested in [1]).
>>> which windows version (7, 8)? any antivirus software?
>>> I saw the problem with both versions. I can't check the antivirus now
>>> but that might be causing it.
>> Cannot check for Windows 8, just for 7 64bit. I'm using Microsoft
>> Security Essentials but it makes no difference whether it's enabled or
>> not. No luck even with forced administrative privileges during setup
>> and/or runtime. Also just checked with the newest build
>> (WinGRASS-7.0.0svn-r61811-1073).
>> I've however multiple copies of msvcr71.dll installed on my system with
>> the one in C:\Windows\Microsoft.NET\Framework\v1.1.4322\msvcr71.dll
>> being most relevant I assume.
>> Copying them manually in extrabin still does the trick.
>> Cheers,
>> Johannes
> any chance to test standalone winGRASS7.1
> (http://wingrass.fsv.cvut.cz/grass71/) above r62082?
installation (including opting for downloading the MS runtimes) and
start of winGRASS 7.1 (WinGRASS-7.1.svn-r62087-1088-Setup) worked like a
charm.
Thanks for fixing it.
Cheers,
Johannes
Geoinformation Systems - Technische Universität Dresden, Germany
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140926/3558e434/attachment.pgp>
