[GRASS-dev] G7 blockers call
Helmut Kudrnovsky hellik at web.de
Thu Sep 25 06:35:46 PDT 2014
Johannes Brauner wrote
> Hi,
> On 05.09.2014 23:57, Anna Petrášová wrote:
>> On Fri, Sep 5, 2014 at 4:17 PM, Helmut Kudrnovsky <
> hellik@
> > <mailto:
> hellik@
> >> wrote:
>>     >>But doing the steps from the
>>     >> installer manually works (the third suggestion). This was the case
>> on
>>     >> two (or more) computers already.
>>     >I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
>>     >Installing with admin priviliges and checking the box for the MS
>> runtime
>>     >environments didn't help but copying the DLLs manually to extrabin
>> did
>>     >the trick (as suggested in [1]).
>>     which windows version (7, 8)? any antivirus software?
>> I saw the problem with both versions. I can't check the antivirus now
>> but that might be causing it.
> Cannot check for Windows 8, just for 7 64bit. I'm using Microsoft
> Security Essentials but it makes no difference whether it's enabled or
> not. No luck even with forced administrative privileges during setup
> and/or runtime. Also just checked with the newest build
> (WinGRASS-7.0.0svn-r61811-1073).
> I've however multiple copies of msvcr71.dll installed on my system with
> the one in C:\Windows\Microsoft.NET\Framework\v1.1.4322\msvcr71.dll
> being most relevant I assume.
> Copying them manually in extrabin still does the trick.
> Cheers,
> Johannes
any chance to test standalone winGRASS7.1
(http://wingrass.fsv.cvut.cz/grass71/) above r62082?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164141.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
