[GRASS-dev] G7 blockers call
Anna Petrášová kratochanna at gmail.com
Thu Sep 25 10:42:16 PDT 2014
On Thu, Sep 25, 2014 at 9:59 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> >Great, I will try tomorrow. I need to ask someone to try it, on the
> computers I have access to, it was
> >working before.
> Are you sure that it has ever worked? Download, unzip and untar the archive
> was working, regarding installing and copying I'm not sure ...
Sure, it was and is still working on certain computers when I check it in
the wizard.
I was wondering if the fontconfig problem I asked earlier could be somehow
related. You haven't probably experienced this problem. I will see after
the testing.
> >Have you identified the problem or are you still guessing?
> I've changed the logic order in the script.
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164149.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140925/ff5e9479/attachment.html>
