[GRASS-dev] G7 blockers call
Helmut Kudrnovsky
hellik at web.de
Fri Sep 26 00:57:03 PDT 2014
Hi Anna,
Anna Petrášová wrote
> On Thu, Sep 25, 2014 at 9:59 AM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> hi,
>> >Great, I will try tomorrow. I need to ask someone to try it, on the
>> computers I have access to, it was
>> >working before.
>> Are you sure that it has ever worked? Download, unzip and untar the
>> archive
>> was working, regarding installing and copying I'm not sure ...
> Sure, it was and is still working on certain computers when I check it in
> the wizard.
> I was wondering if the fontconfig problem I asked earlier could be somehow
> related. You haven't probably experienced this problem. I will see after
> the testing.
WinGRASS-7.1.svn-r62087-1088-Setup.exe works now here on my side regarding
installing and copying runtime files; als Johannes confirmed it also.
regarding the fontconfig problem, it may be related?
is there popping up a MS windows console window with following message
during installation?:
"Generating the font configuration file by scanning various directories for
fonts.
Please wait. Console window will close automatically ...."
any other message in this console window?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164298.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
