[GRASS-dev] g7 addon scripts not working with trunk due to command syntax/option differences
Helmut Kudrnovsky
hellik at web.de
Tue Sep 30 04:54:16 PDT 2014
hi,
all g7 addon scripts which are using e.g. v.to.rast or g.remove are not
working due to command syntax differences.
e.g. in v.to.rast in trunk:
- option 'rows' removed
- instead option 'memory' added
e.g. in g.remove
- g.remove rast=soils (g7) -> g.remove -f type=rast pattern=soils (trunk)
any idea if these syntax differences between g7 and trunk will be backported
at any stage?
if not how to proceed with addon scripts which depend upon some changed
options/syntax?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/g7-addon-scripts-not-working-with-trunk-due-to-command-syntax-option-differences-tp5164964.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
