[GRASS-dev] g7 addon scripts not working with trunk due to command syntax/option differences
Moritz Lennert
mlennert at club.worldonline.be
Tue Sep 30 05:10:04 PDT 2014
On 30/09/14 13:54, Helmut Kudrnovsky wrote:
> hi,
> all g7 addon scripts which are using e.g. v.to.rast or g.remove are not
> working due to command syntax differences.
> e.g. in v.to.rast in trunk:
> - option 'rows' removed
> - instead option 'memory' added
> e.g. in g.remove
> - g.remove rast=soils (g7) -> g.remove -f type=rast pattern=soils (trunk)
> any idea if these syntax differences between g7 and trunk will be backported
> at any stage?
I would plead for a backport to 7.0. These are important syntax changes
in much-used modules, so they should, IMHO, be applied before we push
out a new major version.
Moritz
