[GRASS-dev] g7 addon scripts not working with trunk due to command syntax/option differences
Vaclav Petras
wenzeslaus at gmail.com
Tue Sep 30 07:38:09 PDT 2014
On Tue, Sep 30, 2014 at 8:10 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 30/09/14 13:54, Helmut Kudrnovsky wrote:
>> hi,
>> all g7 addon scripts which are using e.g. v.to.rast or g.remove are not
>> working due to command syntax differences.
>> e.g. in v.to.rast in trunk:
>> - option 'rows' removed
>> - instead option 'memory' added
>> e.g. in g.remove
>> - g.remove rast=soils (g7) -> g.remove -f type=rast pattern=soils (trunk)
>> any idea if these syntax differences between g7 and trunk will be
>> backported
>> at any stage?
> I would plead for a backport to 7.0. These are important syntax changes in
> much-used modules, so they should, IMHO, be applied before we push out a
> new major version.
> Sure, they must be backported (before the final release). Now we are at
testing phase. Testing and feedback (very) welcome. See the ticket:
http://trac.osgeo.org/grass/ticket/2414#comment:8
Once we are satisfied and sure that it is what we want, we can backport.
Diff for addons would be great.
There is a page where all changes should be specified:
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140930/4dcce5d0/attachment.html>
