[GRASS-dev] g7 addon scripts not working with trunk due to command syntax/option differences
Anna Petrášová kratochanna at gmail.com
Tue Sep 30 07:40:23 PDT 2014
On Tue, Sep 30, 2014 at 10:38 AM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Tue, Sep 30, 2014 at 8:10 AM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
>> On 30/09/14 13:54, Helmut Kudrnovsky wrote:
>>> hi,
>>> all g7 addon scripts which are using e.g. v.to.rast or g.remove are not
>>> working due to command syntax differences.
>>> e.g. in v.to.rast in trunk:
>>> - option 'rows' removed
>>> - instead option 'memory' added
>>> e.g. in g.remove
>>> - g.remove rast=soils (g7) -> g.remove -f type=rast pattern=soils (trunk)
>>> any idea if these syntax differences between g7 and trunk will be
>>> backported
>>> at any stage?
>> I would plead for a backport to 7.0. These are important syntax changes
>> in much-used modules, so they should, IMHO, be applied before we push out a
>> new major version.
>> Sure, they must be backported (before the final release). Now we are at
> testing phase. Testing and feedback (very) welcome. See the ticket:
> http://trac.osgeo.org/grass/ticket/2414#comment:8
Also related ticket which should be addressed before backporting:
http://trac.osgeo.org/grass/ticket/2437
<http://trac.osgeo.org/grass/ticket/2437#comment:1>
Anna
> Once we are satisfied and sure that it is what we want, we can backport.
> Diff for addons would be great.
> There is a page where all changes should be specified:
> http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140930/0c3c2cd7/attachment-0001.html>
