[GRASS-dev] Inconsistent number of columns in the table
Anna Petrášová
kratochanna at gmail.com
Fri Apr 3 05:34:45 PDT 2015
On Fri, Apr 3, 2015 at 5:22 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> After importing a vector map in GRASS GIS, when I try to open the table
> manager, I get the message that there is a "Inconsistent number of columns
> in the table <reptiles_east_Africa>"
> I can open the same table without problems in sqlite managers such as
> navigat and sqlite manager.
> I suspect the text in one or more of the entries contains a character that
> is interpreted as delimiter by the table manager. What characters are
> interpreted as delimiters by the table manager (so I know what to look
> for)? Or is there another likely reason for this problem?
That's weird because the separator is composed of multiple characters (it
is string '{_sep_}'), so very unlikely to be in the data. Could you share
the data to test?
Anna
> Paulo
> Running GRASS 7dev on Linux.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150403/c09e25b6/attachment.html>
