[GRASS-dev] Inconsistent number of columns in the table
Anna Petrášová
kratochanna at gmail.com
Fri Apr 3 07:42:21 PDT 2015
On Fri, Apr 3, 2015 at 8:34 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Fri, Apr 3, 2015 at 5:22 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> After importing a vector map in GRASS GIS, when I try to open the table
>> manager, I get the message that there is a "Inconsistent number of columns
>> in the table <reptiles_east_Africa>"
>> I can open the same table without problems in sqlite managers such as
>> navigat and sqlite manager.
>> I suspect the text in one or more of the entries contains a character
>> that is interpreted as delimiter by the table manager. What characters are
>> interpreted as delimiters by the table manager (so I know what to look
>> for)? Or is there another likely reason for this problem?
> That's weird because the separator is composed of multiple characters (it
> is string '{_sep_}'), so very unlikely to be in the data. Could you share
> the data to test?
New ticket:
http://trac.osgeo.org/grass/ticket/2640
There is a newline in record #406, try to remove it first (it shouldn't be
there anyway in this case), then it should work.
> Anna
>> Paulo
>> Running GRASS 7dev on Linux.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150403/b1e66303/attachment.html>
