[GRASS-dev] Inconsistent number of columns in the table
Paulo van Breugel p.vanbreugel at gmail.com
Fri Apr 3 07:53:36 PDT 2015
On Fri, Apr 3, 2015 at 4:42 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Fri, Apr 3, 2015 at 8:34 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Fri, Apr 3, 2015 at 5:22 AM, Paulo van Breugel <p.vanbreugel at gmail.com
>> > wrote:
>>> After importing a vector map in GRASS GIS, when I try to open the table
>>> manager, I get the message that there is a "Inconsistent number of columns
>>> in the table <reptiles_east_Africa>"
>>> I can open the same table without problems in sqlite managers such as
>>> navigat and sqlite manager.
>>> I suspect the text in one or more of the entries contains a character
>>> that is interpreted as delimiter by the table manager. What characters are
>>> interpreted as delimiters by the table manager (so I know what to look
>>> for)? Or is there another likely reason for this problem?
>> That's weird because the separator is composed of multiple characters (it
>> is string '{_sep_}'), so very unlikely to be in the data. Could you share
>> the data to test?
> New ticket:
> http://trac.osgeo.org/grass/ticket/2640
> There is a newline in record #406, try to remove it first (it shouldn't be
> there anyway in this case), then it should work.
Thanks Anna. Out of curiosity, and so I can find this kind of problems
myself next time, how did you find the problematic line?
>> Anna
>>> Paulo
>>> Running GRASS 7dev on Linux.
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150403/c2da4cb9/attachment.html>
