[GRASS-dev] Inconsistent number of columns in the table
Anna Petrášová kratochanna at gmail.com
Fri Apr 3 08:00:59 PDT 2015
On Fri, Apr 3, 2015 at 10:53 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On Fri, Apr 3, 2015 at 4:42 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Fri, Apr 3, 2015 at 8:34 AM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> On Fri, Apr 3, 2015 at 5:22 AM, Paulo van Breugel <
>>> p.vanbreugel at gmail.com> wrote:
>>>> After importing a vector map in GRASS GIS, when I try to open the table
>>>> manager, I get the message that there is a "Inconsistent number of columns
>>>> in the table <reptiles_east_Africa>"
>>>> I can open the same table without problems in sqlite managers such as
>>>> navigat and sqlite manager.
>>>> I suspect the text in one or more of the entries contains a character
>>>> that is interpreted as delimiter by the table manager. What characters are
>>>> interpreted as delimiters by the table manager (so I know what to look
>>>> for)? Or is there another likely reason for this problem?
>>> That's weird because the separator is composed of multiple characters
>>> (it is string '{_sep_}'), so very unlikely to be in the data. Could you
>>> share the data to test?
>> New ticket:
>> http://trac.osgeo.org/grass/ticket/2640
>> There is a newline in record #406, try to remove it first (it shouldn't
>> be there anyway in this case), then it should work.
> Thanks Anna. Out of curiosity, and so I can find this kind of problems
> myself next time, how did you find the problematic line?
I put some print statements in gui/wxpython/dbmgr/base.py and the last
printed record was the bad one.
>>> Anna
>>>> Paulo
>>>> Running GRASS 7dev on Linux.
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150403/f88ee477/attachment-0001.html>
