[GRASS-dev] [GRASS GIS] #2651: Increase maximum number of vector points available
GRASS GIS trac at osgeo.org
Thu Apr 9 05:40:07 PDT 2015
 Reporter:  dnewcomb                  |       Owner:  grass-dev@…
     Type:  enhancement               |      Status:  new
 Priority:  normal                    |   Milestone:  7.1.0
Component:  Vector                    |     Version:  svn-trunk
 Keywords:  lidar, vector point data  |    Platform:  Unspecified
      Cpu:  Unspecified               |
Comment(by dnewcomb):
 Replying to [comment:6 marisn]:
 > Could you, please, copy / paste exact message text?
 > It could be as simple as wrong formatting character used while printing
 message or overflowing counter used just to print progress.
 v.in.lidar -t -o -b input=/media/Seagate Expansion
 Drive/BladenCoNC/bladen_ground0.laz output=bladen_ground_pts
 Over-riding projection check
 Scanning -1879965037 points...
 When I ran v.in.lidar on the previous version of GRASS 7 that I was using,
 I ran v.info on the resulting vector data set and go the same number for
 the number of points .
 Here is the info on the lidar file:
 newcomb at IFW4FO-RAL-SGIS:/media/Seagate Expansion Drive/BladenCoNC$
 ~/lastools/lastools/bin/lasinfo bladen_ground0.laz
 reporting all LAS header entries:
   file signature:             'LASF'
   file source ID:             0
   global_encoding:            1
   project ID GUID data 1-4:   00000000-0000-0000-0000-000000000000
   version major.minor:        1.3
   system identifier:          'LAStools (c) by Martin Isenburg'
   generating software:        'lasmerge (version 131210)'
   file creation day/year:     252/2014
   header size:                235
   offset to point data:       345
   number var. length records: 1
   point data format:          3
   point data record length:   34
   number of point records:    2415002259
   number of points by return: 1503313306 704621650 204714902 2216754
 135647
   scale factor x y z:         0.01 0.01 0.01
   offset x y z:               -0 -0 -0
   min x y z:                  2030000.00 225000.00 3.92
   max x y z:                  2244999.99 404999.99 174.24
Ticket URL: <http://trac.osgeo.org/grass/ticket/2651#comment:7>
