[GRASS-dev] [GRASS GIS] #2651: Increase maximum number of vector points available
trac at osgeo.org
Thu Apr 9 05:59:10 PDT 2015
Reporter: dnewcomb | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: lidar, vector point data | Platform: Unspecified
Cpu: Unspecified |
Comment(by dnewcomb):
Replying to [comment:7 dnewcomb]:
Looking back, this seems to be a duplication of this ticket, which I
forgotten I had submitted
http://trac.osgeo.org/grass/ticket/2472
> Replying to [comment:6 marisn]:
> > Could you, please, copy / paste exact message text?
> > It could be as simple as wrong formatting character used while
printing message or overflowing counter used just to print progress.
> v.in.lidar -t -o -b input=/media/Seagate Expansion
Drive/BladenCoNC/bladen_ground0.laz output=bladen_ground_pts
> Over-riding projection check
> Scanning -1879965037 points...
> When I ran v.in.lidar on the previous version of GRASS 7 that I was
using, I ran v.info on the resulting vector data set and go the same
number for the number of points .
> Here is the info on the lidar file:
> newcomb at IFW4FO-RAL-SGIS:/media/Seagate Expansion Drive/BladenCoNC$
~/lastools/lastools/bin/lasinfo bladen_ground0.laz
> reporting all LAS header entries:
> file signature: 'LASF'
> file source ID: 0
> global_encoding: 1
> project ID GUID data 1-4: 00000000-0000-0000-0000-000000000000
> version major.minor: 1.3
> system identifier: 'LAStools (c) by Martin Isenburg'
> generating software: 'lasmerge (version 131210)'
> file creation day/year: 252/2014
> header size: 235
> offset to point data: 345
> number var. length records: 1
> point data format: 3
> point data record length: 34
> number of point records: 2415002259
> number of points by return: 1503313306 704621650 204714902 2216754
135647
> scale factor x y z: 0.01 0.01 0.01
> offset x y z: -0 -0 -0
> min x y z: 2030000.00 225000.00 3.92
> max x y z: 2244999.99 404999.99 174.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2651#comment:8>
