[GRASS-dev] mathjax support for GRASS manual pages
Sat Apr 11 13:30:19 PDT 2015
Pietro wrote:
> What do you think if we start supporting mathjax on the html webpages?
The main drawbacks of doing so are:
1. It's likely to mess up the nroff manual pages which are generated
from the HTML versions (unless someone's planning on adding code to
g.html2man to recognise the mathjax portions and re-write them using
eqn syntax).
2. It won't work with HTML viewers which don't support JavaScript
(AFAICT, the wx.html control used by wxGUI doesn't). Or images (e.g.
lynx/links).
3. Network access is required to read the manual pages, even when
stored locally. This also has privacy implications.
