[GRASS-dev] Error messages when installing addons
Paulo van Breugel p.vanbreugel at gmail.com
Mon Apr 13 01:31:05 PDT 2015
I updated a number of extensions, all which installed successfully.
However, for four (g.cloud, r.mcda.roughset, r.futures, v.area.stats) I got
some error messages. Not sure they are relevant, but though I might as well
report them. I am running GRASS dev (rev 65027) on Linux (Ubuntu 14.04).
*g.cloud*
g.extension extension=g.cloud
operation=add
WARNING: Extension <g.cloud> already installed. Re-installing...
Fetching <g.cloud> from GRASS-Addons SVN repository (be patient)...
Compiling...
Makefile:16: warning: overriding commands for target
`/tmp/tmpIdTTFc/g.cloud/etc/g.cloud'
/usr/local/grass7/grass-7.1.svn/include/Make/ScriptRules.mak
e:19: warning: ignoring old commands for target
Installing...
Updating addons metadata file...
Installation of <g.cloud> successfully finished
*r.mcda.roughset*
g.extension extension=r.mcda.roughset
operation=add
WARNING: Extension <r.mcda.roughset> already installed. Re-installing...
Fetching <r.mcda.roughset> from GRASS-Addons SVN repository (be patient)...
Compiling...
WARNING: BUG in option name, 'outputMap' is not valid
WARNING: BUG in option name, 'outputTxt' is not valid
Installing...
Installation of <r.mcda.roughset> successfully finished
*r.futures*
g.extension extension=r.futures
operation=add
WARNING: Extension <r.futures> already installed. Re-installing...
Fetching <r.futures> from GRASS-Addons SVN repository (be patient)...
Compiling...
main.cpp: In function ‘int main(int, char**)’:
main.cpp:2512:67: warning: suggest parentheses around
assignment used as truth value [-Wparentheses]
                                     if (pPtr =
strchr(inBuff, ',')) {
main.cpp: In function ‘void
findAndSortProbsAll(t_Landscape*, t_Params*, int)’:
main.cpp:2663:55: warning: comparison between signed and
unsigned integer expressions [-Wsign-compare]
                         pLandscape->asUndevs[id].size())
main.cpp: In function ‘int readData(t_Landscape*,
t_Params*)’:
main.cpp:639:71: warning: ‘iVal’ may be used
uninitialized in this function [-Wmaybe-uninitialized]
pLandscape->asCells[i].bUndeveloped = iVal;
main.cpp:689:52: warning: ‘y’ may be used uninitialized
                     G_message(_("x=%d y=%d"), x, y);
main.cpp:2426:21: warning: ‘seed_value’ may be used
     srand(seed_value);
Installing...
Installation of <r.futures> successfully finished
*v.area.stats*
g.extension extension=v.area.stats
operation=add
WARNING: Extension <v.area.stats> already installed. Re-installing...
Fetching <v.area.stats> from GRASS-Addons SVN repository (be patient)...
Compiling...
export.c: In function ‘export2csv’:
export.c:97:4: warning: format not a string literal and no
format arguments [-Wformat-security]
    printf(buf);
Installing...
Installation of <v.area.stats> successfully finished
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150413/6b37a423/attachment.html>
