[GRASS-dev] [GRASS GIS] #2654: r.thin crashes
trac at osgeo.org
Thu Apr 16 20:02:47 PDT 2015
Reporter: pairmand | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Raster | Version: 7.0.0
Keywords: r.thin | Platform: MSWindows 7
Cpu: x86-64 |
r.thin crashes (Windows message that GRASS 7 has stopped working).
The input was first imported from the attached Erdas Imagine file into a
new location (EPSG:2193), then thinned using the following commands;
r.in.gdal input=D:\temp_work\temukaSub_rasterEdges.img output=rasterEdges
--overwrite -e
r.thin --overwrite --quiet input=rasterEdges output=thinnedRaster
iterations=200
If the If the extent is not set using -e on the import, then it fails with
"Unable to find bounding box for lines" but doesn't crash.
I have tried the same on Linux machine and in that case the "crash" has a
message: "Error writing temporary file".
It has identical to above if the extent has not been defined (earlier
versions of GRASS seemed to handle this).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2654>
