[GRASS-dev] OSX 10.11 Compiling (was: Re: New section in GRASS wiki for installation under Mac using homebrew)
Carlos Grohmann carlos.grohmann at gmail.com
Sun Aug 2 06:32:53 PDT 2015
Hello Rainer (and devs)
I think you only need to join the beta program (although I have the free
developer account, just to be able to download xcode-related tools like the
comand line tools).
I'll summarise what I know so far about these issues:
- When compiling, I get a lot of errors. These are related to creating html
docs. As Glynn said, at this pint of compilation, the module is run
with  --html-description
switch to get a list of its options. Any problems with wxpython will cause
an error here.
- Running make in the module directory show a call to
libgrass_gis.7.0.1svn.dylib,
but with the wrong path. It tries to load the library from the final
package path (after installation), which doesn't exists yet..
see the last lines of this output:
cd scripts/d.correlate/
GuanoAFBIOTA:d.correlate guano$ make
if [
"/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
!= "" ] ; then
GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
d.correlate.tmp.html ; fi
dyld: Library not loaded:
/Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
  Referenced from:
/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
  Reason: image not found
make: *** [d.correlate.tmp.html] Error 1
rm d.correlate.tmp.html
- Ignoring the error and creating the package will work, and the package
will install, although when run, the GUI will fail:
>>> from grass.pygrass import messages
  File "<stdin>", line 1, in <module>
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
line 19, in <module>
    import grass.lib.gis as libgis
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
line 23, in <module>
    _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
line 57, in load_library
    raise ImportError,"%s not found." % libname
ImportError: grass_gis.7.0.1RC2 not found.
cheers
Carlos
On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> Envoyé de mon iPhone
> Le 31 juil. 2015 à 23:07, Carlos Grohmann <carlos.grohmann at gmail.com> a
> écrit :
> Hi
> The homebrew formula doesn't really work on OSX 10.11 beta. In the log
> file (attached) I can see the same errors in compilation I got when tried
> to compile svn. They are related to html manual pages, but prevent
> installation from continue.
> As I do not have 10.11 beta I can't check it. But please let me (and
> osgeo4mac) know when you found a solution as I think it will also affect
> 6.4x and 7.0x versions.
> Do I have to have a developer account with apple to have access to the
> beta?
> Cheers
> Rainer
> Carlos
> brew tap rkrug/head-only
> ==> Tapping rkrug/head-only
> Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
> remote: Counting objects: 4, done.
> remote: Compressing objects: 100% (4/4), done.
> remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
> Unpacking objects: 100% (4/4), done.
> Checking connectivity... done.
> Tapped 1 formula (27 files, 116K)
> brew install grass-71
> Error: rkrug/head-only/grass-71 is a head-only formula
> Install with `brew install --HEAD rkrug/head-only/grass-71`
> Warning: You are using OS X 10.11.
> We do not provide support for this pre-release version.
> You may encounter build failures or other breakage.
> ==> Installing grass-71 from rkrug/homebrew-head-only
> Error: No available formula for nc_spm_08_grass7 (dependency of
> rkrug/head-only/grass-71)
> guano$ brew install --HEAD rkrug/head-only/grass-71
> --without-nc_spm_08_grass7
> ==> Cloning https://svn.osgeo.org/grass/grass/trunk
> Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
> ==> Patching
> patching file include/Make/Install.make
> Hunk #1 succeeded at 116 (offset 2 lines).
> ==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared
> --with-
> ==> make GDAL_DYNAMIC=
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Fri Jul 31 17:36:12 BRT 2015
> make: *** [default] Error 1
> READ THIS: https://git.io/brew-troubleshooting
> If reporting this issue please do so at (not Homebrew/homebrew):
>   https://github.com/rkrug/homebrew-head-only/issues
> GuanoAFBIOTA:~ guano$
> On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <
> carlos.grohmann at gmail.com> wrote:
>> Very interesting!
>> From the brew recipe, it looks that one needs all dependencies installed
>> via homebrew, is that right? I'm thinking that most will have Kyngsburie's
>> Frameworks already installed (at least GDAL). Same goes for wx-python.
>> best
>> Carlos
>> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>> Anna Petrášová <kratochanna at gmail.com> writes:
>>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer at krugs.de>
>>> wrote:
>>> >> Hi
>>> >> I just added a section / new page in the WIKI for installation of
>>> GRASS
>>> >> using homebrew. Please see
>>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
>>> >> and
>>> >> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
>>> >> It would be great if some Mac / homebrew users would see if it works
>>> and
>>> >> give me comments here.
>>> > I will try to test it next week. Thank you for your efforts!
>>> Great - let me know how it goes, although I don't know if I will be able
>>> to reply as I am away and possibly only have very limited internet
>>> access.
>>> Thanks,
>>> Rainer
>>> > Anna
>>> >> Cheers,
>>> >> Rainer
>>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>> >> Biology, UCT), Dipl. Phys. (Germany)
>>> >> Centre of Excellence for Invasion Biology
>>> >> Stellenbosch University
>>> >> South Africa
>>> >> Tel :       +33 - (0)9 53 10 27 44
>>> >> Cell:       +33 - (0)6 85 62 59 98
>>> >> Fax :       +33 - (0)9 58 10 27 44
>>> >> Fax (D):    +49 - (0)3 21 21 25 22 44
>>> >> email:      Rainer at krugs.de
>>> >> Skype:      RMkrug
>>> >> PGP: 0x0F52F982
>>> >> _______________________________________________
>>> >> grass-dev mailing list
>>> >> grass-dev at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>> South Africa
>>> Skype:      RMkrug
>>> PGP: 0x0F52F982
>> Prof. Carlos Henrique Grohmann
>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> http://carlosgrohmann.com
>> http://orcid.org/0000-0001-5073-5572
>> ________________
>> Can’t stop the signal.
> ________________
> <02.make>
________________
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150802/f3673342/attachment-0001.html>
