[GRASS-dev] OSX 10.11 Compiling
Rainer M Krug
Rainer at krugs.de
Tue Aug 4 06:52:29 PDT 2015
Carlos Grohmann <carlos.grohmann at gmail.com> writes:
> Hello Rainer (and devs)
> I think you only need to join the beta program (although I have the free
> developer account, just to be able to download xcode-related tools like the
> comand line tools).
Thanks - I registered for the beta program an I am downloading El
Capitan at the moment.
Can you give any pointers how I can install it in Virtual Box as I do
not want to interfere with my production machine and do prefer the
flexibility of a virtual machine.
I'll take a look at the errors when I have it installed - which might be
in two weeks time as I will be on holiday next week.
Thanks,
Rainer
> I'll summarise what I know so far about these issues:
> - When compiling, I get a lot of errors. These are related to creating html
> docs. As Glynn said, at this pint of compilation, the module is run
> with --html-description
> switch to get a list of its options. Any problems with wxpython will cause
> an error here.
> - Running make in the module directory show a call to
> libgrass_gis.7.0.1svn.dylib,
> but with the wrong path. It tries to load the library from the final
> package path (after installation), which doesn't exists yet..
> see the last lines of this output:
> cd scripts/d.correlate/
> GuanoAFBIOTA:d.correlate guano$ make
> if [
> "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
> != "" ] ; then
> GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
> GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
> PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
> PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
> DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
> LC_ALL=C
> --html-description < /dev/null | grep -v '</body>\|</html>' >
> d.correlate.tmp.html ; fi
> dyld: Library not loaded:
> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
> Referenced from:
> /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
> Reason: image not found
> make: *** [d.correlate.tmp.html] Error 1
> rm d.correlate.tmp.html
> - Ignoring the error and creating the package will work, and the package
> will install, although when run, the GUI will fail:
>>>> from grass.pygrass import messages
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
> line 19, in <module>
> import grass.lib.gis as libgis
> File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
> line 23, in <module>
> _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
> File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
> line 57, in load_library
> raise ImportError,"%s not found." % libname
> ImportError: grass_gis.7.0.1RC2 not found.
> cheers
> Carlos
> On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>> Envoyé de mon iPhone
>> Le 31 juil. 2015 à 23:07, Carlos Grohmann <carlos.grohmann at gmail.com> a
>> écrit :
>> Hi
>> The homebrew formula doesn't really work on OSX 10.11 beta. In the log
>> file (attached) I can see the same errors in compilation I got when tried
>> to compile svn. They are related to html manual pages, but prevent
>> installation from continue.
>> As I do not have 10.11 beta I can't check it. But please let me (and
>> osgeo4mac) know when you found a solution as I think it will also affect
>> 6.4x and 7.0x versions.
>> Do I have to have a developer account with apple to have access to the
>> beta?
>> Cheers
>> Rainer
>> Carlos
>> brew tap rkrug/head-only
>> ==> Tapping rkrug/head-only
>> Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
>> remote: Counting objects: 4, done.
>> remote: Compressing objects: 100% (4/4), done.
>> remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
>> Unpacking objects: 100% (4/4), done.
>> Checking connectivity... done.
>> Tapped 1 formula (27 files, 116K)
>> brew install grass-71
>> Error: rkrug/head-only/grass-71 is a head-only formula
>> Install with `brew install --HEAD rkrug/head-only/grass-71`
>> Warning: You are using OS X 10.11.
>> We do not provide support for this pre-release version.
>> You may encounter build failures or other breakage.
>> ==> Installing grass-71 from rkrug/homebrew-head-only
>> Error: No available formula for nc_spm_08_grass7 (dependency of
>> rkrug/head-only/grass-71)
>> guano$ brew install --HEAD rkrug/head-only/grass-71
>> --without-nc_spm_08_grass7
>> ==> Cloning https://svn.osgeo.org/grass/grass/trunk
>> Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
>> ==> Patching
>> patching file include/Make/Install.make
>> Hunk #1 succeeded at 116 (offset 2 lines).
>> ==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared
>> --with-
>> ==> make GDAL_DYNAMIC=
>> appear in the error log. If you get an error building a library, you will
>> also get errors from anything which uses the library.
>> Finished compilation: Fri Jul 31 17:36:12 BRT 2015
>> make: *** [default] Error 1
>> READ THIS: https://git.io/brew-troubleshooting
>> If reporting this issue please do so at (not Homebrew/homebrew):
>> https://github.com/rkrug/homebrew-head-only/issues
>> GuanoAFBIOTA:~ guano$
>> On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <
>> carlos.grohmann at gmail.com> wrote:
>>> Very interesting!
>>> From the brew recipe, it looks that one needs all dependencies installed
>>> via homebrew, is that right? I'm thinking that most will have Kyngsburie's
>>> Frameworks already installed (at least GDAL). Same goes for wx-python.
>>> best
>>> Carlos
>>> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>> Anna Petrášová <kratochanna at gmail.com> writes:
>>>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer at krugs.de>
>>>> wrote:
>>>> >> Hi
>>>> >> I just added a section / new page in the WIKI for installation of
>>>> GRASS
>>>> >> using homebrew. Please see
>>>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
>>>> >> and
>>>> >> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
>>>> >> It would be great if some Mac / homebrew users would see if it works
>>>> and
>>>> >> give me comments here.
>>>> > I will try to test it next week. Thank you for your efforts!
>>>> Great - let me know how it goes, although I don't know if I will be able
>>>> to reply as I am away and possibly only have very limited internet
>>>> access.
>>>> Thanks,
>>>> Rainer
>>>> > Anna
>>>> >> Cheers,
>>>> >> Rainer
>>>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>>> >> Biology, UCT), Dipl. Phys. (Germany)
>>>> >> Centre of Excellence for Invasion Biology
>>>> >> Stellenbosch University
>>>> >> South Africa
>>>> >> Tel : +33 - (0)9 53 10 27 44
>>>> >> Cell: +33 - (0)6 85 62 59 98
>>>> >> Fax : +33 - (0)9 58 10 27 44
>>>> >> Fax (D): +49 - (0)3 21 21 25 22 44
>>>> >> email: Rainer at krugs.de
>>>> >> Skype: RMkrug
>>>> >> PGP: 0x0F52F982
>>>> >> _______________________________________________
>>>> >> grass-dev mailing list
>>>> >> grass-dev at lists.osgeo.org
>>>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>>> South Africa
>>>> Skype: RMkrug
>>>> PGP: 0x0F52F982
>>> Prof. Carlos Henrique Grohmann
>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>> http://carlosgrohmann.com
>>> http://orcid.org/0000-0001-5073-5572
>>> ________________
>>> Can’t stop the signal.
>> ________________
>> <02.make>
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150804/95f05a6a/attachment.pgp>
