[GRASS-dev] OSX 10.11 Compiling
Carlos Grohmann
carlos.grohmann at gmail.com
Wed Aug 5 05:31:49 PDT 2015
Hi
I never installed OS X on a virtual machine, can't help much there.. (I'm
using yosemite as primary machine and El Capitan on a secondary one)
While we are here, I tried the homebrew tap for 7.1svn on a Yosemite
machine and it didn't worked.
First I tried to install with libLas, add although it installed libels
correctly, it can't find the library when running GRASS'configure
:==> ./configure --prefix=/usr/local/Cellar/grass-71/HEAD --enable-shared
--with-
checking for gdal-config... /usr/local/opt/gdal/bin/gdal-config
rm: conftest.dSYM: is a directory
checking whether to use libLAS... yes
checking for liblas-config... /usr/local/opt/liblas/bin/liblas-config
configure: error: *** Unable to locate libLAS library.
Then I tried with libels and it went OK, but when I run:
Serenity:~ guano$ /usr/local/bin/grass71
File "/usr/local/bin/grass71", line 54, in <module>
ENCODING = locale.getdefaultlocale()[1]
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py",
line 511, in getdefaultlocale
return _parse_localename(localename)
File
line 443, in _parse_localename
raise ValueError, 'unknown locale: %s' % localename
ValueError: unknown locale: UTF-8
Serenity:~ guano$
any ideas?
thanks
Carlos
On Tue, Aug 4, 2015 at 10:52 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Carlos Grohmann <carlos.grohmann at gmail.com> writes:
> > Hello Rainer (and devs)
> > I think you only need to join the beta program (although I have the free
> > developer account, just to be able to download xcode-related tools like
> the
> > comand line tools).
> Thanks - I registered for the beta program an I am downloading El
> Capitan at the moment.
> Can you give any pointers how I can install it in Virtual Box as I do
> not want to interfere with my production machine and do prefer the
> flexibility of a virtual machine.
> I'll take a look at the errors when I have it installed - which might be
> in two weeks time as I will be on holiday next week.
> Thanks,
> Rainer
> > I'll summarise what I know so far about these issues:
> > - When compiling, I get a lot of errors. These are related to creating
> html
> > docs. As Glynn said, at this pint of compilation, the module is run
> > with --html-description
> > switch to get a list of its options. Any problems with wxpython will
> cause
> > an error here.
> > - Running make in the module directory show a call to
> > libgrass_gis.7.0.1svn.dylib,
> > but with the wrong path. It tries to load the library from the final
> > package path (after installation), which doesn't exists yet..
> > see the last lines of this output:
> > cd scripts/d.correlate/
> > GuanoAFBIOTA:d.correlate guano$ make
> > if [
> "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
> > != "" ] ; then
> GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
> GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
> PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
> PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
> DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
> > LC_ALL=C
> > --html-description < /dev/null | grep -v '</body>\|</html>' >
> > d.correlate.tmp.html ; fi
> > dyld: Library not loaded:
> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
> > Referenced from:
> /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
> > Reason: image not found
> > make: *** [d.correlate.tmp.html] Error 1
> > rm d.correlate.tmp.html
> > - Ignoring the error and creating the package will work, and the package
> > will install, although when run, the GUI will fail:
> >>>> from grass.pygrass import messages
> > File "<stdin>", line 1, in <module>
> > File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/pygrass/messages/__init__.py",
> > line 19, in <module>
> > import grass.lib.gis as libgis
> > File
> > "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/gis.py",
> > line 23, in <module>
> > _libs["grass_gis.7.0.1RC2"] = load_library("grass_gis.7.0.1RC2")
> > File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/lib/ctypes_loader.py",
> > line 57, in load_library
> > raise ImportError,"%s not found." % libname
> > ImportError: grass_gis.7.0.1RC2 not found.
> > cheers
> > Carlos
> > On Sun, Aug 2, 2015 at 7:51 AM, Rainer M Krug <r.m.krug at gmail.com>
> wrote:
> >> Envoyé de mon iPhone
> >> Le 31 juil. 2015 à 23:07, Carlos Grohmann <carlos.grohmann at gmail.com> a
> >> écrit :
> >> Hi
> >> The homebrew formula doesn't really work on OSX 10.11 beta. In the log
> >> file (attached) I can see the same errors in compilation I got when
> tried
> >> to compile svn. They are related to html manual pages, but prevent
> >> installation from continue.
> >> As I do not have 10.11 beta I can't check it. But please let me (and
> >> osgeo4mac) know when you found a solution as I think it will also affect
> >> 6.4x and 7.0x versions.
> >> Do I have to have a developer account with apple to have access to the
> >> beta?
> >> Cheers
> >> Rainer
> >> Carlos
> >> brew tap rkrug/head-only
> >> ==> Tapping rkrug/head-only
> >> Cloning into '/usr/local/Library/Taps/rkrug/homebrew-head-only'...
> >> remote: Counting objects: 4, done.
> >> remote: Compressing objects: 100% (4/4), done.
> >> remote: Total 4 (delta 0), reused 4 (delta 0), pack-reused 0
> >> Unpacking objects: 100% (4/4), done.
> >> Checking connectivity... done.
> >> Tapped 1 formula (27 files, 116K)
> >> brew install grass-71
> >> Error: rkrug/head-only/grass-71 is a head-only formula
> >> Install with `brew install --HEAD rkrug/head-only/grass-71`
> >> Warning: You are using OS X 10.11.
> >> We do not provide support for this pre-release version.
> >> You may encounter build failures or other breakage.
> >> ==> Installing grass-71 from rkrug/homebrew-head-only
> >> Error: No available formula for nc_spm_08_grass7 (dependency of
> >> rkrug/head-only/grass-71)
> >> guano$ brew install --HEAD rkrug/head-only/grass-71
> >> --without-nc_spm_08_grass7
> >> ==> Cloning https://svn.osgeo.org/grass/grass/trunk
> >> Updating /Library/Caches/Homebrew/grass-71--svn-HEAD
> >> ==> Patching
> >> patching file include/Make/Install.make
> >> Hunk #1 succeeded at 116 (offset 2 lines).
> >> --with-
> >> ==> make GDAL_DYNAMIC=
> >> appear in the error log. If you get an error building a library, you
> will
> >> also get errors from anything which uses the library.
> >> Finished compilation: Fri Jul 31 17:36:12 BRT 2015
> >> make: *** [default] Error 1
> >> READ THIS: https://git.io/brew-troubleshooting
> >> If reporting this issue please do so at (not Homebrew/homebrew):
> >> https://github.com/rkrug/homebrew-head-only/issues
> >> GuanoAFBIOTA:~ guano$
> >> On Fri, Jul 31, 2015 at 11:54 AM, Carlos Grohmann <
> >> carlos.grohmann at gmail.com> wrote:
> >>> Very interesting!
> >>> From the brew recipe, it looks that one needs all dependencies
> installed
> >>> via homebrew, is that right? I'm thinking that most will have
> Kyngsburie's
> >>> Frameworks already installed (at least GDAL). Same goes for wx-python.
> >>> best
> >>> Carlos
> >>> On Fri, Jul 31, 2015 at 5:44 AM, Rainer M Krug <Rainer at krugs.de>
> wrote:
> >>>> Anna Petrášová <kratochanna at gmail.com> writes:
> >>>> > On Thu, Jul 30, 2015 at 6:38 AM, Rainer M Krug <Rainer at krugs.de>
> >>>> wrote:
> >>>> >> Hi
> >>>> >> I just added a section / new page in the WIKI for installation of
> >>>> GRASS
> >>>> >> using homebrew. Please see
> >>>> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX
> >>>> >> and
> >>>> >> http://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
> >>>> >> It would be great if some Mac / homebrew users would see if it
> works
> >>>> and
> >>>> >> give me comments here.
> >>>> > I will try to test it next week. Thank you for your efforts!
> >>>> Great - let me know how it goes, although I don't know if I will be
> able
> >>>> to reply as I am away and possibly only have very limited internet
> >>>> access.
> >>>> Thanks,
> >>>> Rainer
> >>>> > Anna
> >>>> >> Cheers,
> >>>> >> Rainer
> >>>> >> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> >>>> >> Biology, UCT), Dipl. Phys. (Germany)
> >>>> >> Centre of Excellence for Invasion Biology
> >>>> >> Stellenbosch University
> >>>> >> South Africa
> >>>> >> Tel : +33 - (0)9 53 10 27 44
> >>>> >> Cell: +33 - (0)6 85 62 59 98
> >>>> >> Fax : +33 - (0)9 58 10 27 44
> >>>> >> Fax (D): +49 - (0)3 21 21 25 22 44
> >>>> >> email: Rainer at krugs.de
> >>>> >> Skype: RMkrug
> >>>> >> PGP: 0x0F52F982
> >>>> >> _______________________________________________
> >>>> >> grass-dev mailing list
> >>>> >> grass-dev at lists.osgeo.org
> >>>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> >>>> South Africa
> >>>> Skype: RMkrug
> >>>> PGP: 0x0F52F982
> >>> Prof. Carlos Henrique Grohmann
> >>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> >>> - Digital Terrain Analysis | GIS | Remote Sensing -
> >>> http://carlosgrohmann.com
> >>> http://orcid.org/0000-0001-5073-5572
> >>> ________________
> >>> Can’t stop the signal.
> >> ________________
> >> <02.make>
> South Africa
> Skype: RMkrug
> PGP: 0x0F52F982
________________
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150805/ce6b5fae/attachment-0001.html>
