[GRASS-dev] installing v.mapcalc fails
Markus Neteler
neteler at osgeo.org
Sun Aug 2 11:38:26 PDT 2015
On Fri, Jul 24, 2015 at 11:49 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> installing v.mapcalc fails,
Which operating system?
> with the following:
> g.extension extension=v.mapcalc
> svnurl=http://svn.osgeo.org/grass/grass-addons/grass7
> Fetching <v.mapcalc> from GRASS-Addons SVN repository (be patient)...
> Compiling...
> yylex.c: In function ‘yylex’:
> yylex.c:32:7: warning: ignoring return value of ‘scanf’,
> declared with attribute warn_unused_result [-Wunused-result]
> scanf("%lf", &yylval.dbl);
> make: *** [v.mapcalc.tmp.html] Error 1
> ERROR: Compilation failed, sorry. Please check above error messages.
I have applied some Makefile fixes (perhaps unrelated), pls try again.
Markus
