[GRASS-dev] doxygen installation
Rob Parsons jrobparsons at gmail.com
Sun Aug 2 11:05:50 PDT 2015
Yes.
I will update the wiki once I get everything working.
Here is what I had to do to get document generation to complete
successfully:
Build documentation
Install latest Graphviz binary distribution for windows from here:
http://graphviz.org/Download_windows.php
Install latest Doxygen binary distribution for Windows from here:
http://www.stack.nl/~dimitri/doxygen/download.html
Install latest basic TeX/LaTeX system for Windows from here:
http://miktex.org/download
After the TeX/LaTeX system is installed, and during the first time 'make
pdfdocs' is run, expect to be prompted for additional packages that must be
installed to complete the TeX/LaTex system.
In MSYS shell, add the path to doxygen.exe and dot.exe
$ export PATH=$PATH:/c/"Program Files"/doxygen/bin
$ export PATH=$PATH:/c/graphviz-2.38/release/bin
$ export PATH=$PATH:/c/"Program Files (x86)"/"MiKTeX 2.9"/miktex/bin
$ echo $PATH
$ cd /c/OSGeo4W/src/grass7_trunk/
$ make htmldocs
$ make pdfdocs
Regards,
Rob Parsons
Raleigh NC
On Wed, Jul 29, 2015 at 9:06 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Jul 26, 2015 at 1:42 PM, Rob Parsons <jrobparsons at gmail.com>
> wrote:
> > Hi,
> > I am building up (slowly) a Windows 7 Eclipse (Mars) development
> > environment.
> If it makes sense, please consider to eventually update
> http://grasswiki.osgeo.org/wiki/Eclipse
> > I have installed the OSGeo4W instrastructure.
> > I have installed the 'grass7_trunk' SVN repository locally under
> > C:\OSGeo4W\src.
> > I want to run:
> > make htmldocs
> > make pdfdocs
> > I know I need to run 'make' from the MSYS shell.
> > How/where do you normally install doxygen in this particular development
> > environment?
> > From MSYS shell:
> > Ruth at Ruth-PC ~
> > $ which doxygen
> > which: doxygen: unknown command
> > Ruth at Ruth-PC ~
> > $ where doxygen
> > INFO: Could not find files for the given pattern(s).
> > Ruth at Ruth-PC ~
> > $ echo $PATH
> .:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/windows/system32:/c/windows:/c/windows/WBem:/usr/bin:/osgeo4w/apps/Python27/Scripts
> > From OSGeo4W shell:
> > C:\Users\Ruth\Desktop>where doxygen
> > C:\Program Files\doxygen\bin\doxygen.exe
> Please try
> echo $PATH
> also in the OSGeo4W shell, perhaps there is a subtle difference. Or,
> add C:\Program Files\doxygen\bin\ to the path in MSYS.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150802/a9090e4b/attachment.html>
