[GRASS-dev] C syntax and the use of underscore ('_')
Rob Parsons
jrobparsons at gmail.com
Mon Aug 24 22:08:47 PDT 2015
Ok.
I am getting smarter.
Forget what I said about using the -std=c99 option to get Eclipse to
recognize the _() macro. The syntax error being reported by the Eclipse
editor (CDT parser) is caused be the definition of PACKAGE on the gcc
command line.
-DPACKAGE=\""grassmods"\"
Eclipse invokes the GRASS 'make default' tool and builds the system or
module with no problem. The Eclipse parser/indexer builds its database of
symbols and cross-references by scanning all the C/C++ source code, Python
scripts and make output.
It learns that the value of PACKAGE is the string:
\""grassmods"\"
This value is OK when building the system or module because the build is
performed within a MSYS shell.
The Eclipse editor and CDT parser likes this value:
"grassmods"
I am not suggesting any kind of change. The _() macro works. I can
successfully compile and from within Eclipse. The 'syntax error' is more of
a nuisance than anything else. Maybe I can figure out how to tell Eclipse
to ignore this syntax.
Eclipse 4.5 Mars for GRASS development on Windows 7 is working very well. I
can browse, build, run, debug GRASS C/C+ modules and Python scripts.
I will document this on the wiki.
Rob Parsons
Raleigh NC
On Mon, Aug 3, 2015 at 8:57 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Aug 3, 2015 at 2:26 PM, Rob Parsons <jrobparsons at gmail.com> wrote:
> > Telling Eclipse that the C dialect is c99 (-std=c99) solved the problem.
> The
> > macro is now recognized.
> Excellent. Please consider to update the page
> http://grasswiki.osgeo.org/wiki/Eclipse
> in order to help others with the hint(s) which easily get lost in the
> email archive.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150825/0ed5c588/attachment.html>
