[GRASS-dev] [GRASS GIS] #2721: t.rast.what: allow stdin and add to GRASS 7.0
trac at osgeo.org
Fri Aug 14 03:01:32 PDT 2015
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.2
Component: Default | Version: unspecified
Keywords: t.rast.what | CPU: Unspecified
Platform: All |
Please find attached a diff which allows t.rast.what to read from stdin.
That way it becomes also possible to add a site name to the output, which
is pretty useful for later useage of it...
The site name is only propagated to the output, when a site name has been
provided in the (first line of the) input.
There are probably more elegant solutions for this, so improvements are
very welcome. I did not update the manual and the test suite yet, but I
will try to do so, if you consider this addition useful too...
For users with "commandlineophobia" it would be probably better to specify
coordinates using the file option G_OPT_F_INPUT?
Furthermore, the script works very well in GRASS 7.0 too. Any particular
reason for not shipping it with the stable release? t.rast.what is a
pretty handy tool!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2721>
