[GRASS-dev] Python scripts receiving input from the GRASS GUI?
Michel Wortmann
wortmann at pik-potsdam.de
Wed Aug 19 08:33:08 PDT 2015
Hi Vaclav,
thanks for the ideas. I have already implemented an idea which I find
works very well and is based on an add on, which works well with GRASS'
existing addon structure. But it did require me to add a few lines in
the gui_core.query as well as the dbmgr.base python files, which I guess
is the downside of it. Here is the implementation:
g.gui.triggers is a little addon that manages a sqlite table
(__triggers__) in the current mapset, it records the vector name, the
command and the argument=column mapping and additional arguments to be
used. It can also be called with the arguments map= and cat= to actually
do the triggering of the command listed in the table for the respective cat.
To implement the dbmgr double-clicking, I add the following to
dbmgr.base to call g.gui.triggers if the addon exists and if the vector
is listed in the __triggers__ table.
%%%% in header:
try: import guitriggers
except: guitriggers=None
%%%% line 1063
if guitriggers and
guitriggers.hasTrigger(**{a:self.dbMgrData['mapDBInfo'].layers[layer][a]
for a in ['table','database']}):
win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataTrigger)
win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataTrigger)
elif UserSettings.Get(group = 'atm', key = 'leftDbClick',
subkey = 'selection') == 0:
%%%% anywhere as method to the DbMgrBrowsePage class
def OnDataTrigger(self,event):
info = self.dbMgrData['mapDBInfo'].layers[self.selLayer]
tlist = self.FindWindowById(self.layerPage[self.selLayer]['data'])
# get categories
cats = map(int,tlist.GetSelectedItems())
guitriggers.trigger(info['table'],cats,database=info['database'])
return
To implement the selection idea in the map display, I added a check box
to the query dialog (if the addon exists). If it is checked, the command
listed in the __triggers__ table is executed. I added the following to
the gui_core.query file:
%%%% in header:
%%%% in QueryDialog.__init__ line 77
if guitriggers:
self.trigger = wx.CheckBox(self.panel, label=_("Enable
trigger"))
self.trigger.SetValue(False)
hbox = wx.BoxSizer(wx.HORIZONTAL)
hbox.Add(item=self.trigger, proportion=0, flag=wx.EXPAND |
wx.RIGHT, border=5)
self.mainSizer.Add(item=hbox, proportion=0, flag=wx.EXPAND |
wx.ALL, border=5)
%%%% in QueryDialog.SetData, line 99
if guitriggers and self.trigger.IsChecked():
for m in data[1:]:
info = m[m.keys()[0]] #unpack
try:
guitriggers.trigger(info['Table'].split()[0],[info['Category']],
database=info['Database'].split()[0])
except: pass
I have not found any major flaws with this approach, the only downside
being the few added lines in the existing code (which are all pretty
much copied from existing functionalities). The 'guitriggers' module is
so far still imported as a python module, but I guess it doesnt take
much to check whether it's an installed addon.
Let me know if you want more details or would like me to upload the
addon to the GRASS addon repro.
Regards,
Michel
On 08/19/2015 03:47 PM, Vaclav Petras wrote:
> Hi Michel,
> On Thu, Aug 13, 2015 at 10:32 AM, Michel Wortmann
> <wortmann at pik-potsdam.de <mailto:wortmann at pik-potsdam.de>> wrote:
> Dear Devs,
> what would be the best and least invasive way of receiving input
> from the grass GUI to use in python scripts. The following
> functionalities are on my mind:
> - when double-clicking a line in the dbmgr, trigger a
> script/function using the line's content as input
> - when selecting a feature in the map display, trigger a
> script/function using the query results as input
> I guess changing the effect of a dbmgr line double-click can only
> be changed by fiddling with the gui/wxpython/dbmgr module files.
> Receiving the select query results as input on the command line is
> in theory possible with the 'Redirect to console' option in the
> select pop-up, but how can I read the GUI console?
> In case someone had similar intentions and has some clues, I would
> appreciate hearing about them.
> these are reasonable requests. I suppose this would make your module
> more convenient for users to use. Unfortunately, there is no easy way.
> Anyway, these are the options:
> 1. Create a new functionality similar to the button to select
> coordinates. Module would specify option type as feature ID and when
> the module's GUI is started from the main GUI, the button is
> associated with Map Display. User clicks the button. Clicks in Map
> Display. Some query function is invoked and result goes to the input
> field in module's GUI. There is already a "template" for implementing
> this - the coordinates button.
> 2. Create a plugin system for wxGUI (thanks to Python relatively
> simple) and writing a plugin. If somebody wants to do that, please
> contact me, I can give you few pointers.
> 3. Create a new feature in GUI Command Console to start a module with
> current output in console as standard input for the module. I'm not
> sure if this would overcomplicate things or how this can be made
> actually convenient for users, but it is en interesting option.
> 4. For attribute data (dbmgr), "copy and paste" the line's content can
> be enough. Same for query results. For query, the copy is implemented
> but the format might not be good for parsing. For dbmgr, the button to
> copy should be easy to add. This seems convenient enough for user.
> I suggest to first check the option number 4. The most general option
> is number 2 but when implemented, it would require writing a module to
> do the processing and then also a plugin for GUI to do the
> interaction. In this light option number 1 seems as a good way.
> Best,
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150819/7e355ab5/attachment.html>
