[GRASS-dev] New Mac binaries uploaded
William Kyngesburye woklist at kyngchaos.com
Mon Aug 24 09:56:12 PDT 2015
Michael, you may need to recompile your las tools to use the current GDAL, this is separate from GRASS compilation.
On Aug 24, 2015, at 10:31 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Anna,
> These work for me and at least some of my students here. So we need to find out why they don't work for you. I'm teaching spatial tech this fall and want to make sure others don't run into trouble. 7.0.1 was a completely fresh checkout and 7.1 was compiled after a make distclean.
> Do you have any idea what causes this error? Did you install a new gdal? I compiled with William's most current version. I am still using stock Mac Python and wx version 2.8.12. Have you installed anything newer in the testing I saw on the list?
> Michael Barton
> School of Human Evolution &Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> ...Sent from my iPad
> On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>> Hi Michael,
>> sorry to report but the new binaries (70 and 71) don't work, the gui doesn't open with this error. I already saw this error multiple times and it might be enough just to make distclean and recompile or fresh svn checkout.
>> GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent call last):
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 140, in <module>
>>     sys.exit(main())
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 132, in main
>>     app = GMApp(workspaceFile)
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 46, in __init__
>>     wx.App.__init__(self, False)
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
>>     self._BootstrapApp()
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
>>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 79, in OnInit
>>     from lmgr.frame import GMFrame
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 50, in <module>
>>     from lmgr.layertree        import LayerTree, LMIcons
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py", line 37, in <module>
>>     from mapdisp.frame        import MapFrame
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py", line 34, in <module>
>>     from vdigit.toolbars    import VDigitToolbar
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py", line 30, in <module>
>>     from iclass.digit       import IClassVDigit
>>   File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py", line 23, in <module>
>>     from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
>> ImportError: cannot import name TYPE_AREA
>> Also, v.in.lidar or las2las (anything using liblas) doesn't work. I don't have GDAL 1.10, but 1.11.
>> dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
>>   Referenced from: /Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
>>   Reason: image not found
>> Trace/BPT trap: 5
>> If you don't have time to look at it now, could you please post the GRASS 7.0.0 binary which I believe worked.
>> Thank you,
>> Anna
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
