[GRASS-dev] New Mac binaries uploaded
Michael Barton
Michael.Barton at asu.edu
Mon Aug 24 10:08:35 PDT 2015
Yes. The LAS tools are compiled for GDAL 1.10. They were a royal pain to compile. The instructions to the newest LAStools source code makes it sound like it is much easier now. Does anyone have any experience with the current version? I was going to try it but wanted to make sure I had a GRASS version out with at least a clunky working version before risking it.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Aug 24, 2015, at 9:56 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Michael, you may need to recompile your las tools to use the current GDAL, this is separate from GRASS compilation.
> On Aug 24, 2015, at 10:31 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> Anna,
>> These work for me and at least some of my students here. So we need to find out why they don't work for you. I'm teaching spatial tech this fall and want to make sure others don't run into trouble. 7.0.1 was a completely fresh checkout and 7.1 was compiled after a make distclean.
>> Do you have any idea what causes this error? Did you install a new gdal? I compiled with William's most current version. I am still using stock Mac Python and wx version 2.8.12. Have you installed anything newer in the testing I saw on the list?
>> Michael Barton
>> School of Human Evolution &Social Change
>> ...Sent from my iPad
>> On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>> Hi Michael,
>>> sorry to report but the new binaries (70 and 71) don't work, the gui doesn't open with this error. I already saw this error multiple times and it might be enough just to make distclean and recompile or fresh svn checkout.
>>> GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent call last):
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 140, in <module>
>>> sys.exit(main())
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 132, in main
>>> app = GMApp(workspaceFile)
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 46, in __init__
>>> wx.App.__init__(self, False)
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
>>> self._BootstrapApp()
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line 79, in OnInit
>>> from lmgr.frame import GMFrame
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py", line 50, in <module>
>>> from lmgr.layertree import LayerTree, LMIcons
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py", line 37, in <module>
>>> from mapdisp.frame import MapFrame
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py", line 34, in <module>
>>> from vdigit.toolbars import VDigitToolbar
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py", line 30, in <module>
>>> from iclass.digit import IClassVDigit
>>> File "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py", line 23, in <module>
>>> from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
>>> ImportError: cannot import name TYPE_AREA
>>> Also, v.in.lidar or las2las (anything using liblas) doesn't work. I don't have GDAL 1.10, but 1.11.
>>> dyld: Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
>>> Referenced from: /Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
>>> Reason: image not found
>>> Trace/BPT trap: 5
>>> If you don't have time to look at it now, could you please post the GRASS 7.0.0 binary which I believe worked.
>>> Thank you,
>>> Anna
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
