[GRASS-dev] New Mac binaries uploaded
Newcomb, Doug
doug_newcomb at fws.gov
Mon Aug 24 10:29:53 PDT 2015
Liblas or LASTools?
Doug
On Mon, Aug 24, 2015 at 1:08 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> Yes. The LAS tools are compiled for GDAL 1.10. They were a royal pain to
> compile. The instructions to the newest LAStools source code makes it sound
> like it is much easier now. Does anyone have any experience with the
> current version? I was going to try it but wanted to make sure I had a
> GRASS version out with at least a clunky working version before risking it.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> > On Aug 24, 2015, at 9:56 AM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > Michael, you may need to recompile your las tools to use the current
> GDAL, this is separate from GRASS compilation.
> > On Aug 24, 2015, at 10:31 AM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
> >> Anna,
> >> These work for me and at least some of my students here. So we need to
> find out why they don't work for you. I'm teaching spatial tech this fall
> and want to make sure others don't run into trouble. 7.0.1 was a completely
> fresh checkout and 7.1 was compiled after a make distclean.
> >> Do you have any idea what causes this error? Did you install a new
> gdal? I compiled with William's most current version. I am still using
> stock Mac Python and wx version 2.8.12. Have you installed anything newer
> in the testing I saw on the list?
> >> Michael Barton
> >> School of Human Evolution &Social Change
> >> ...Sent from my iPad
> >> On Aug 24, 2015, at 7:43 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> >>> Hi Michael,
> >>> sorry to report but the new binaries (70 and 71) don't work, the gui
> doesn't open with this error. I already saw this error multiple times and
> it might be enough just to make distclean and recompile or fresh svn
> checkout.
> >>> GRASS 7.1.svn (loc_ncarolina_spm_base0.3.1):~ > Traceback (most recent
> call last):
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/wxgui.py", line
> 140, in <module>
> >>> sys.exit(main())
> >>> File
> 132, in main
> >>> app = GMApp(workspaceFile)
> >>> File
> 46, in __init__
> >>> wx.App.__init__(self, False)
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/etc/python/wx/_core.py", line
> 7981, in __init__
> >>> self._BootstrapApp()
> >>> File
> 7555, in _BootstrapApp
> >>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> >>> File
> 79, in OnInit
> >>> from lmgr.frame import GMFrame
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
> line 50, in <module>
> >>> from lmgr.layertree import LayerTree, LMIcons
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
> line 37, in <module>
> >>> from mapdisp.frame import MapFrame
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
> line 34, in <module>
> >>> from vdigit.toolbars import VDigitToolbar
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
> line 30, in <module>
> >>> from iclass.digit import IClassVDigit
> >>> File
> "/Applications/GRASS-7.1.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
> line 23, in <module>
> >>> from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
> >>> ImportError: cannot import name TYPE_AREA
> >>> Also, v.in.lidar or las2las (anything using liblas) doesn't work. I
> don't have GDAL 1.10, but 1.11.
> >>> dyld: Library not loaded:
> /Library/Frameworks/GDAL.framework/Versions/1.10/GDAL
> >>> Referenced from:
> /Applications/GRASS-7.1.app/Contents/MacOS/lib/liblas.2.2.0.dylib
> >>> Reason: image not found
> >>> Trace/BPT trap: 5
> >>> If you don't have time to look at it now, could you please post the
> GRASS 7.0.0 binary which I believe worked.
> >>> Thank you,
> >>> Anna
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> > Second Pogril: I don't know. Why IS life like sticking your head in a
> bucket filled with hyena offal?
> > First Pogril: I don't know either. Wretched, isn't it?
> > -HitchHiker's Guide to the Galaxy
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior. Life is too short for undocumented, proprietary data formats.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150824/a9879c43/attachment-0001.html>
