[GRASS-dev] g.gui.metadata and wxgui addons in GRASS 7.1
Matej Krejci matejkrejci at gmail.com
Tue Aug 25 03:05:52 PDT 2015
Hi Stephan,
I can browse the maps in my mapset and the pen and the “template” button
> get active. Yet, when I click on “template” I get:
> WARNING: Epsg code cannot be identified
> Traceback (most recent call last):
>   File "/usr/local/grass-7.1.svn/scripts/g.gui.metadata", line 291, in
> onCreateTemplate
>     if self.onEdit():
>   File "/usr/local/grass-7.1.svn/scripts/g.gui.metadata", line 303, in
> onEdit
>     ok = self.editMapMetadata()
>   File "/usr/local/grass-7.1.svn/scripts/g.gui.metadata", line 648, in
> editMapMetadata
>     self.xmlPath = self.mdCreator.saveXML(self.mdDestination,
> self.nameTMPteplate, self)
>   File "/usr/local/grass-7.1.svn/etc/wx.metadata/mdlib/mdgrass.py", line
> 513, in saveXML
>     profile = env.get_template(self.profilePath)
>   File
> "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.dev-py2.7.egg/jinja2/environment.py",
> line 812, in get_template
>     return self._load_template(name, self.make_globals(globals))
>   File
> line 774, in _load_template
>     cache_key = self.loader.get_source(self, name)[1]
>   File
> "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.dev-py2.7.egg/jinja2/loaders.py",
> line 187, in get_source
>     raise TemplateNotFound(template)
> jinja2.exceptions.TemplateNotFound:
> etc/wx.metadata/profiles/basicProfile.xml
Current revision is 66011. Before was everything defined fixedly to grass
addons environment/base. Now it should work in all way of installation.
please try:
sudo make MODULE_TOPDIR=/usr/local/grass-7.1.svn
sudo make MODULE_TOPDIR=/usr/local/grass-7.1.svn install
folders with metadata libs, profiles and configure files need make install.
The location was defined using an EPSG code (25632). It is a standard
> ETRS/UTM based CRS which is quite common for the western to central parts
> of Europe (and INSPIRE compliant)…
This warning does not affect for something important.  Only auto
identifying EPSG from WKT proj is not successful which means that the
metadata attribute has not value. I changed warning to message because a
lots of attributes cannot be filled from r/v.info.
> Anyway, the first glimpse I got from g.gui.metadata looked promising!
> Thanks for your work on that!
big thanks for your endurance :-)
Matej
------------- dal�� ��st ---------------
HTML p��loha byla odstran�na...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150825/4fd9e6e8/attachment.html>
