[GRASS-dev] Travis CI
Rainer M Krug
Rainer at krugs.de
Thu Aug 27 05:32:04 PDT 2015
Hi Ivan, Hi Markus,
I have looked at the .travis.yml at
[https://trac.osgeo.org/grass/browser/grass/trunk/.travis.ym]l
and merged it with mine by
1) moving the sections of the .travis.yml fiole into scripts:
- before_install :: .travis.$TRAVIS_OS_NAME.before_install.sh
- install :: .travis.$TRAVIS_OS_NAME.install.sh
- script :: .travis.$TRAVIS_OS_NAME.script.sh
2) using a travis multiple OS [http://docs.travis-ci.com/user/multi-os/]
which sets the variable $TRAVIS_OS_NAME to "osx" or "linux" (hopefully
"windows" in the future as well)
So when testing on linux, the scripts with *.linux.*.sh are called, when
testing osx the one=s with *.osx.*.sh get called
3) adding the different compiler to the matrix
So I end up with three separate test scenarios:
| - os: linux
| language: c
| compiler: gcc
| - os: linux
| language: c
| compiler: clang
| - os: osx
| compiler: objective-c
I forked [https://github.com/GRASS-GIS/grass-ci] and am running the test
at the moment - see [https://travis-ci.org/rkrug/grass-ci/builds/77484863]
for the tests.
They completed successful.
There is still some fine tuning which could be done, especially with
including of tests - which should not be to difficult.
What would be the easiest to get the new files into the grass repo, id=f
you are happy with it?
Cheers,
Rainer
Markus Neteler <neteler at osgeo.org> writes:
> Hi Ivan,
> I asked Rainer who is willing to contribute the MacOSX part (end of the month).
> See below.
> Thanks, Rainer!
> Markus
> On Fri, Aug 14, 2015 at 10:09 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>> Envoyé de mon iPhone
>>> Le 14 août 2015 à 09:45, Markus Neteler <neteler at osgeo.org> a écrit :
>>> Hi Rainer,
>> Hi Markus,
>>> given your experience with homebrew, I wondered if you would be
>>> willing to assist in setting up a Travis-CI instance for OSX here:
>> Yes - That is my idea. To have a Travis-CI instance for all major OS should be the aim.
>>>> On Tue, Jul 21, 2015 at 11:52 AM, Ivan Minčík <ivan.mincik at gmail.com> wrote:
>>>> Hi all,
>>>> we have just integrated Travis Continuous Integration system [1] to the
>>>> GRASS source code. Every commit is now build in Travis [2] using gcc and
>>>> clang. In case the build fails, error message should go to GRASS-dev list.
>>>> 1 - https://trac.osgeo.org/grass/browser/grass/trunk/.travis.yml
>>>> 2 - https://travis-ci.org/GRASS-GIS/grass-ci
>>>> Ivan Minčík
>>>> ivan.mincik at gmail.com GPG: 0x79529A1E
>>>> http://imincik.github.io/0x79529A1E.key
>>>> ivan.mincik at gista.sk GPG: 0xD714B02C
>>>> http://imincik.github.io/0xD714B02C.key
>>> This works well for Linux now.
>>> Reading this email on qgis-psc, I got the impression that it is
>>> "simple" also for OSX:
>>>> On Fri, Aug 14, 2015 at 7:31 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>>>> On 13 August 2015 at 04:32, Tim Sutton <tim at qgis.org> wrote:
>>>>> Awesome stuff Nyall - can you give any notes on what specifically you
>>>>> had to do to enable OS X testing?
>>>> Not much really... all the ground work was already in place and were
>>>> just waiting on Travis to open up multi OS builds again. Whoever setup
>>>> the homebrew install package (Larry?) made it super easy to install
>>>> the dependencies, and we already had 99% of the tests passing without
>>>> error on OSX. Michael Kirk had also already given this a shot so I was
>>>> able to borrow parts of his attempts which also helped a lot.
>>>> Nyall
>>>> _______________________________________________
>>>> Qgis-psc mailing list
>>>> Qgis-psc at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-psc
>>> Ivan does not have time for it but he's maybe willing to tell you how
>>> to log into the system.
>>> What do you think?
>> As you probably know, I have a running Travis-ci for OS X and it could be integrated there.
>> The homebrew recipe needs some alignment in this case (and possibly
>> a new more "official" home) but that should be relatively straight
>> forward.
>> At the moment I am on holiday but should be able to look at it in the last week of August.
>> Please remind me of you don't hear from me by end of August.
>> Cheers and thanks for the offer,
>> Rainer
>>> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150827/af79bb58/attachment.pgp>
