[GRASS-dev] [GRASS GIS] #2730: wxGUI: wx.metadata/wx.mwprecip/etc: Unable to fetch interface description for command 'wx.metadata'
trac at osgeo.org
Fri Aug 28 00:50:05 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: interface-description toolboxes
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:1 wenzeslaus]:
> Replying to [ticket:2730 mlennert]:
> > I don't really understand why this has to be called at all when the
user does not have any toolboxes defined...
> The reason is that addon modules go to the module tree in *Search
modules* tab.
Ah, ok. Thanks for the explanation.
> As for the wrong entries, there might be some wrong/insufficient info
coming from g.extension (the list of installed addons is acquired using
`g.extension -a`).
There are no wrong entries. The problem is that g.extension -a lists the
names of extensions that have been installed, but extensions != modules in
some cases. There are, for example, extensions that provide several
modules. So, by using "g.extension -a" you cannot be sure that the names
you get are actually modules that can be called with --interface-
description.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2730#comment:2>
