[GRASS-dev] [GRASS GIS] #2564: r.what: remove 400 maps limit and add some new output options
trac at osgeo.org
Wed Dec 9 01:19:12 PST 2015
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.what
CPU: Unspecified | Platform: Unspecified
Comment (by huhabla):
I would like to see a PyGRASS implementation of r.what that is easier to
maintain. Especially the database handling in PyGRASS is much, much easier
than in C. However, PyGRASS supports only sqlite and postgresql as
backends, since it fully ignores the GRASS database library and uses
Python bindings.
I have implemented a simple prototype to sample a space time raster
dataset with vector points, that allows to have a vector attribute table
column as identifier of the points in the output. It is slower than
t.rast.what but a good example of what can be done using PyGRASS and the
temporal framework.
https://bitbucket.org/huhabla/temporal-raster-sampling/overview
Ticket URL: <http://trac.osgeo.org/grass/ticket/2564#comment:3>
