[GRASS-dev] v.what.vect issues
Johannes Radinger
johannesradinger at gmail.com
Thu Dec 10 05:40:23 PST 2015
Hi all,
I just used v.what.vect for the first time. However, I just found
some minor issues on my GRASS71 setup:
1) The web manual page seems offline or not working:
https://grass.osgeo.org/grass70/manuals/v.what.vect.html
2) Somehow I could not select a query column in the GUI interface. Although
I selected the correct map and layer, I could not select any columns.
Using the command line worked perfectly!
Nothing very important to worry about, but I just wanted to mention it!
Best regards,
Johannes
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151210/bd4ccbbe/attachment.html>
