[GRASS-dev] r.cpt2grass - add option to multiply values
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Dec 15 01:53:45 PST 2015
On 12-12-15 04:21, Anna Petrášová wrote:
> Hi Paulo,
> On Tue, Dec 1, 2015 at 10:17 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> Hi Anna
> Just an idea I got when using r.ctp2grass for some climate data.
> Climate data layers are often multiplied by a factor 10 so they
> can be distributed as integer rasters while still maintaining a
> desired degree of precision. This made me think that it would be
> nice if I could create a color rules file using r.ctp2grass with
> the option to multiply the default values as defined in the ctp
> file. Perhaps something along the lines of attached patch file for
> r.ctp2grass (for illustrative purposes, I am sure things can be
> done better)? Is that something that could be implemented?
> Something similar could perhaps be nice for r.colors as well when
> using one of the included color tables (but only those based on
> values rather than percentages obviously).
> Cheers,
> Paulo
> I can't really judge the usefulness of such option, but if you find it
> useful, then go ahead and commit it. I would just use 'multiply' or
> 'multiplier', not 'multi' as the option name.
Hi Anna, I have been rethinking this option, and it is probably
something that is too specific. For linear scales, the -s flag will be
sufficient, while other color scales will often be tailored to specific
cases anyway.
> Best,
> Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151215/3c845d8c/attachment.html>
