[GRASS-dev] wingrass daily buidls + addons temporary down
Helmut Kudrnovsky hellik at web.de
Thu Dec 17 10:49:07 PST 2015
wenzeslaus wrote
> On Thu, Dec 17, 2015 at 8:51 AM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> >> after some quick tests of some ratser modules: it's quite responsive
> and
>> >> fast ...
>> > it would be interesting to compare with 32bit (new) and also old
>> > (grass 7.0.2-1)... Ma
>> here it is, some quick test:
> Almost twice as fast this is really good! Thanks Martin, the 64bit version
> is useful in general as well.
> Helmut, do you want to try to run all tests to see if they work and if
> there is some visible seed improvement as well?
> Quoting from my previous email about tests on Windows [1]: Install the
> latest build of trunk for Windows. Get the latest source code: If you
> don't
> have Subversion on Windows, checkout the latest version on Linux (or make
> distclean && svn up), zip it and unzip it on Windows. Run GRASS GIS, use
> cmd line, cd into the source code dir and run all tests [2]:
>     python -m grass.gunittest.main --location nc_basic_spm_grass7
> --location-type nc
> [1] https://lists.osgeo.org/pipermail/grass-dev/2015-February/074037.html
> [2]
> http://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html
tests are running, will post the results later. some are failing as it seems
some maps have different names as expected in the tests.
I suggest to link in [1] to the needed nc sample data set version for which
the tests should be run.
[1]
https://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass-daily-buidls-addons-temporary-down-tp5240948p5241813.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
