[GRASS-dev] wingrass daily buidls + addons temporary down
Helmut Kudrnovsky
hellik at web.de
Thu Dec 17 11:01:35 PST 2015
wenzeslaus wrote
> python -m grass.gunittest.main --location nc_basic_spm_grass7
> --location-type nc
how do I know if the test has finished?
after:
C:\OSGeo4W\src\grass7>python -m grass.gunittest.main --location
nc_spm_08_grass7
--location-type nc
test_assertions from .\lib\python\gunittest failed (6 tests failed)
test_assertions_vect from .\lib\python\gunittest failed (6 tests failed)
test_doctests from .\lib\python\gunittest failed (1 test failed)
test_doctests from .\lib\python\pygrass failed (3 tests failed)
test_doctests from .\lib\python\pygrass\modules failed (1 test failed)
test_doctests from .\lib\python\pygrass\modules\interface failed (1 test
failed)
test_modules from .\lib\python\pygrass\modules\interface failed (17 tests
failed
test_category from .\lib\python\pygrass\raster failed (1 test failed)
test_doctests from .\lib\python\pygrass\raster failed (5 tests failed)
test_numpy from .\lib\python\pygrass\raster failed (1 test failed)
test_raster_region from .\lib\python\pygrass\raster failed
the command line seems to be locked, not sure, if the tests are still
running?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass-daily-buidls-addons-temporary-down-tp5240948p5241816.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
