[GRASS-dev] v.net.path issue report
Moritz Lennert mlennert at club.worldonline.be
Fri Dec 18 02:57:28 PST 2015
Hello,
[Please keep communication on the list]
Testing with your data on GNU/Linux I cannot reproduce the problem:
time v.net -c input=palmitalmainApiaiNetout operation=nodes
out=test_network --o
real	0m0.936s
user	0m0.052s
sys	0m0.028s
I currently don't have a running Windows installation available to test
there, so please post a bug report on https://trac.osgeo.org/grass/, if
possible with the data.
Moritz
On 15/12/15 17:50, José Anderson wrote:
> M,
> thanks a lot for asking. I appreciate that.
> Here comes the GRASS location zipped. There is only the line network I
> earned from v.net <http://v.net> (palmitalmainApiaiNetout at PERMANENT).
> I hope to hear from you soon.
> J
> Em ter, 15 de dez de 2015 às 09:12, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
> escreveu:
>     On 15/12/15 15:38, José Anderson wrote:
>      > Hi all, I've been sharing the v.net.path issue I've experiência
>     to the
>      > User's list with no reply.
>      > After trying the command in two windows versions, it seems to me
>     it is a
>      > GRASS core issue that should be reported.
>      > Here is the description below.
>      > I've tried v.net.path over a line network (one branch only) I built
>      > using "v.net <http://v.net> <http://v.net> -c operation=nodes"
>     over win7 and win8.
>      > v.net.path cannot get finished and stays long and long showing the
>      > message "Building graph... Registering arcs..."
>      > I have more details as long as you ask me.
>     Can you reproduce this with the North Carolina Demo dataset ? This would
>     allow others to test. Or make your data available somehow ?
>     Moritz
