[GRASS-dev] v.net.path issue report
José Anderson
joseandersonbatista at gmail.com
Fri Dec 18 06:42:21 PST 2015
Motiz.
I really appreciated your effort in colaborate to this v.net.path test.
So far, it seems v.net.path is not working properly for windows precompiled
GRASS 7.0.
I'm going ahead and provide for myself a linux PC to repeat the test.
Thank you so much.
José
Em sex, 18 de dez de 2015 03:58, Moritz Lennert <
mlennert at club.worldonline.be> escreveu:
> Hello,
> [Please keep communication on the list]
> Testing with your data on GNU/Linux I cannot reproduce the problem:
> time v.net -c input=palmitalmainApiaiNetout operation=nodes
> out=test_network --o
> real 0m0.936s
> user 0m0.052s
> sys 0m0.028s
> I currently don't have a running Windows installation available to test
> there, so please post a bug report on https://trac.osgeo.org/grass/, if
> possible with the data.
> Moritz
> On 15/12/15 17:50, José Anderson wrote:
> > M,
> > thanks a lot for asking. I appreciate that.
> > Here comes the GRASS location zipped. There is only the line network I
> > earned from v.net <http://v.net> (palmitalmainApiaiNetout at PERMANENT).
> > I hope to hear from you soon.
> > J
> > Em ter, 15 de dez de 2015 às 09:12, Moritz Lennert
> > <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
> > escreveu:
> > On 15/12/15 15:38, José Anderson wrote:
> > > Hi all, I've been sharing the v.net.path issue I've experiência
> > to the
> > > User's list with no reply.
> > > After trying the command in two windows versions, it seems to me
> > it is a
> > > GRASS core issue that should be reported.
> > > Here is the description below.
> > > I've tried v.net.path over a line network (one branch only) I
> built
> > > using "v.net <http://v.net> <http://v.net> -c operation=nodes"
> > over win7 and win8.
> > > v.net.path cannot get finished and stays long and long showing the
> > > message "Building graph... Registering arcs..."
> > > I have more details as long as you ask me.
> > Can you reproduce this with the North Carolina Demo dataset ? This
> would
> > allow others to test. Or make your data available somehow ?
> > Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151218/07c6695c/attachment.html>
