[GRASS-dev] [GRASS GIS] #2632: option in context menu to export vector attribute table
trac at osgeo.org
Tue Dec 22 06:47:11 PST 2015
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.3
Component: Vector | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
I added a second patch that puts the (IMHO) main options of v.db.select
(map, column separator, output file) into a "Main choices" tab. I think
this should be enough to make exporting attributes easier, without having
to code a separate simplified GUI. Not sure if "Main choices" is the best
choice of names for that tab, though. Any better ideas are more than
welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2632#comment:5>
