[GRASS-dev] [GRASS GIS] #2632: option in context menu to export vector attribute table
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Dec 22 07:09:00 PST 2015
> Reporter: pvanbosgeo | Owner: grass-dev@…
> Type: enhancement | Status: new
> Priority: normal | Milestone: 7.0.3
> Component: Vector | Version: unspecified
> Resolution: | Keywords:
> CPU: Unspecified | Platform: Unspecified
> Comment (by mlennert):
> I added a second patch that puts the (IMHO) main options of v.db.select
> (map, column separator, output file) into a "Main choices" tab. I think
> this should be enough to make exporting attributes easier, without having
> to code a separate simplified GUI. Not sure if "Main choices" is the best
> choice of names for that tab, though. Any better ideas are more than
> welcome.
Thanks. Unfortunately, I am not sure how to apply/test that patch, is there
a description / grass wiki page somewhere that explains?
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2632#comment:5>
> GRASS GIS <https://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151222/9e3df6cc/attachment.html>
