[GRASS-dev] [GRASS GIS] #2632: option in context menu to export vector attribute table
Moritz Lennert
mlennert at club.worldonline.be
Tue Dec 22 08:26:11 PST 2015
On 22/12/15 16:09, Paulo van Breugel wrote:
> On Tue, Dec 22, 2015 at 3:47 PM, GRASS GIS <trac at osgeo.org
> Reporter: pvanbosgeo | Owner: grass-dev@…
> Type: enhancement | Status: new
> Priority: normal | Milestone: 7.0.3
> Component: Vector | Version: unspecified
> Resolution: | Keywords:
> CPU: Unspecified | Platform: Unspecified
> Comment (by mlennert):
> I added a second patch that puts the (IMHO) main options of
> v.db.select
> (map, column separator, output file) into a "Main choices" tab. I
> think
> this should be enough to make exporting attributes easier, without
> having
> to code a separate simplified GUI. Not sure if "Main choices" is
> the best
> choice of names for that tab, though. Any better ideas are more than
> welcome.
> Thanks. Unfortunately, I am not sure how to apply/test that patch, is
> there a description / grass wiki page somewhere that explains?
https://grasswiki.osgeo.org/wiki/Patches
For the GUI part (export_attributes.patch) you can also copy the changes
manually into gui/wxpython/lmgr/layertree.py in your GRASS installation
directory (GISBASE).
For the v.db.select change you need to patch (or apply manually - there
are not that many changes) and then recompile the module.
Moritz
