[GRASS-dev] wx.metadata / g.gui.metadata another problem in pdf export
Paulo van Breugel p.vanbreugel at gmail.com
Tue Dec 22 09:40:28 PST 2015
When saving the metadata to pdf the 'use constraints' field is not handled
correctly. Even when filled in, in the pdf output it shows 'unknown' under
the use constraints header.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151222/08355234/attachment.html>
