[GRASS-dev] wx.metadata / g.gui.metadata another problem in pdf export
Matej Krejci matejkrejci at gmail.com
Wed Dec 23 06:54:19 PST 2015
Hi Paulo,
problem with use constraints is fixed in r67340.
Thanks for the report.
Matej
On Tue, Dec 22, 2015 at 6:40 PM Paulo van Breugel <p.vanbreugel na gmail.com>
wrote:
> When saving the metadata to pdf the 'use constraints' field is not handled
> correctly. Even when filled in, in the pdf output it shows 'unknown' under
> the use constraints header.
------------- další část ---------------
HTML příloha byla odstraněna...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151223/d4a12f37/attachment.html>
