[GRASS-dev] wx.metadata / g.gui.metadata another problem in pdf export
Paulo van Breugel p.vanbreugel at gmail.com
Wed Dec 23 07:19:38 PST 2015
On 23-12-15 15:54, Matej Krejci wrote:
> Hi Paulo,
> problem with use constraints is fixed in r67340.
> Thanks for the report.
> Matej
Thanks, will try it out
> On Tue, Dec 22, 2015 at 6:40 PM Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>     When saving the metadata to pdf the 'use constraints' field is not
>     handled correctly. Even when filled in, in the pdf output it shows
>     'unknown' under the use constraints header.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151223/13e338fa/attachment.html>
