[GRASS-dev] grouping most important parameters in a 'main' tab
Moritz Lennert mlennert at club.worldonline.be
Wed Dec 23 03:19:19 PST 2015
Hello all,
In a response to #2632 [1], I changed v.db.select in trunk (r67337) in
order to reorder parameters in the module GUI and group what I consider
the most important parameters in a 'Main' tab.
I know there has been much discussion about parameter grouping in the
GUI before and I don't want to impose my choices here. So, I'm more than
happy to revert if necessary.
The main idea is to ease the use of module GUIs without giving up their
complete power. In other words, simplify, without dumming down. If, for
a module, there are some parameters that seem the most obvious ones to
change, then why not regroup them in a 'Main' tab, while leaving the
other, more specialised ones, in separate tabs ?
Please have a look and tell me what you think.
Moritz
[1] https://trac.osgeo.org/grass/ticket/2632
