[GRASS-dev] winGRASS OSGeo4W crashes when switching to 3D view
Helmut Kudrnovsky
hellik at web.de
Mon Dec 28 01:25:02 PST 2015
Markus Neteler wrote
> Hi,
> while teaching our IRSAE course
> (http://gis.cri.fmach.it/grass-gis-and-r-course/) we did not have
> success to perform a NVIZ exercise on Windows.
> Switching to 3D mode leads to a GUI crash when loading the "elevation"
> DEM. We used "elevation" in the new (yet to be improved) Piemont
> location [1].
> No error message shown, just crash.
> If anyone wants to test:
> wget http://geodati.fmach.it/gfoss_geodata/grassdata_course_version1.7z
> # unpack (7a is contained eg in p7zip-plugins package):
> 7z x grassdata_course_version1.7z
> --> grassdata_piemonte/user1
> Note: It is a new issue since 7.0.1, in 7.0.0 which is installed on
> the same machine no such issue.
> I suspect that it is the elevation map size causing the issue since
> the DEM is larger than that of the NC dataset.
> Markus
I confirm this. in large regions, 3D view crashes.
tested here with
System Info
GRASS Version: 7.0.2
and
System Info
GRASS Version: 7.1.svn
and the piemonte data set (but also with other large rasters):
g.region -p -a raster=elevation at PERMANENT align=elevation at PERMANENT
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5146000
south: 4879500
west: 313000
east: 517000
nsres: 25
ewres: 25
rows: 10660
cols: 8160
cells: 86985600
attached a debug=3 output ( wxnviz_debug.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5243063/wxnviz_debug.txt> )
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/winGRASS-OSGeo4W-crashes-when-switching-to-3D-view-tp5243039p5243063.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
